Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: WHY MOTORCRAFT OIL AND OIL FILTERS???
  1. #11
    13 Post(s)
    Re: WHY MOTORCRAFT OIL AND OIL FILTERS???
    Quote Originally Posted by trbstang
    Acutally, there is no way a dealer can void a warranty claim simply due to not using a Ford Motorcraft or other dealer brand filter or oil, as long as a comparable part is used. If a dealer is doing that, they are in violation of federal law. See the Magnuson-Moss Warranty Act. Now if they give you the oil and filter change for free, then they can specify using certain parts. Of course if the aftermarket part causes a failure, then they can deny it.
    http://www.accessconnect.com/afterma...s-warranty.htm
    I have always used Motorcraft filters on my car, simply because they are reasonable and easy to find.
    "comparable" may not cut it...
    just because it fits does not make it comparable.
    Motorcraft, Purulator and Royal Purple are the only ones that use a siicone anti- drainback valve.
    This is CRITICAL on 3v engines.
    a wise man once said, "you should never deny yourself a donut."
  2. #12
    13 Post(s)
    It appears that the royal purple filter is as good...
    It is also $10 +
    I am offering a group buy on FL 820's and FL1A's @ $2.50 each ( minimum of 12, multiples of twelve).
  3. #13
    Oct 2005
    Rosenberg
    Quote Originally Posted by Fizzy
    x2, There may be an arguement to be made if said filter has the anti- drainback valve. However, I can tell you it would require a call to Ford for prior approval which could delay repair time.
    About the Magnuson-Moss Warranty Act - Just like any law, it has interpretation. Ford can void a warranty if you get your oil changes done at Jiffy Lube and they underfill it, or their crappy filter fails, causing damage to the engine. The tapping in knocking in the 3v is, in our shop at least, almost always related to crappy oil filters. Just like paying the lube shop to perform a flush and they don't use the manufacturer's recommended technique for the service. I.e. fuel injector services. At Ford we tap into the fuel rail as opposed to just taking off a vacuum line or cramming the drip into the intake. Can't tell you how many time I had to explain to customers that Ford won't cover their check engine light because the lube shop didn't follow Ford's proceedure.
    John Smith - Ford Service Advisor
    2005 Mustang GT 5 speed - Sonic Blue, stockish 13.54 @ 106
    1999 Explorer Sport 5 speed - Orange, the boom box/ daily hustler. "Dora"
    2009 Harley Davidson Nightster 1200 - The Death Machine
  4. #14
    3 Post(s)
    Best sticky wicket ever says my wife...
  5. #15
    13 Post(s)
  6. #16
    Nov 2006
    Tomball
    3 (100%)
    Quote Originally Posted by Just Chuck
    Nice!
    It's the soldier not the reporter who gives you freedom of the press.
    It's the soldier not the poet who gives you freedom of speech.
    It's the soldier not the campus organizer who allows you to demonstrate.
    It's the soldier who salutes the flag, serves the flag, whose coffin is draped with the flag that allows protesters to burn it.
  7. #17
    3 Post(s)
    Make sure not to over fill your crank case with oil either. That's why it's better to have a dealer change your oil. They have highly trained oil changing guys that can count to 10.
  8. #18
    Oct 2005
    Rosenberg
    Hey, most all of my lube guys here can count to 20... It only takes them 2 hours to get an oil change done too!!!
  9. #19
    John..you sir are hilarious!!!!
  10. #20
    Oct 2005
    Rosenberg
    Quote Originally Posted by Ricker6869
    really, I wish I was laughing... I'm actually serious
