Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 2006 GT Tranny Swap??
    Oct 2010
    Liberty
    I have an 06 GT with a supercharged aluminator motor with a conservative tune (450 at the tires) that im thinking of converting to a manual 5 or 6 speed (also has 4.10 gear). I know its a lot of work, but it is something I can do. Does anyone know of all the parts I will have to change? Im not sure if I need to replace the computer, or if this one can retuned for the standard transmission. Id really like to find a totaled car for a donor, but im not sure if I will be able to find/afford one. My automatic is built right with no expense spared, but the OD band is out and im not sure I want to spend the money on the automatic, I really wanted a manual when I found this car. Whats yalls thoughts. Thanks
    [/SIGPIC]2006 GT
    Aluminator Motor
    Ford Racing heads
    Stage 2 cams
    Roush TVS supercharger
    GT 500 fuel system upgrade
    Automatic Transmission
    4:10 gears
    May 2009
    Katy, TX
    2 Post(s)
    You'll need a manual pcm, harness, and pedal assembly.
    06 GT. Built by me
    s197forum.com/forum
    12.61 @ 107.78 with a slipping clutch and one-wheel-peel.
    Oct 2010
    Liberty
    Ok, thanks. Any recomendations on a clutch and pressure plate? I just dont want something extremely hard to push, but will hold up to the power im putting to it (530hp at the flywheel).
    Here is what I think I need, does anyone see anything i dont need, or that i forgot?
    Transmission
    Clutch
    Flywheel
    Cross member
    Driveshaft
    PCM
    Wire harness
    Pedal assembly
    Master cylinder
    Slave cylinder
    Line from master cylinder to slave cylinder
    Shifer and linkage
    Thanks for any info that u have.
    Bezel for around shifter
    [/SIGPIC]2006 GT
    Aluminator Motor
    Ford Racing heads
    Stage 2 cams
    4:10 gears
  4. #4
    Plantersville
    13 (100%)
    17 Post(s)
    These cars are hyd clutch so pedal feel isn't bad even with a big clutch.
    I would do a Exeedy Mach500 or 600
    Sent from my iPhone 5S
    2014 GT Premium A6
    Sleeved Block 80MM Billet 3BB Comp turbo Full Suspension tuned by Black Mamba Speed - 138.8mph pedaling on 10psi
  5. #5
    May 2009
    Katy, TX
    2 Post(s)
    Don't need a new master Cylinder or driveshaft
    06 GT. Built by me
    s197forum.com/forum
  6. #6
    Oct 2010
    Liberty
    I was hoping I could use the driveshaft that I already have, so thats some good news. Where is the best place to get the parts from?? I found the tranny, flywheel,shifter, and factory driveshaft for $400, but that still leaves me with several parts to round up. Im assuming that is a fair price. Anybody here have any of the parts I need??
    [/SIGPIC]2006 GT
    Aluminator Motor
    Ford Racing heads
    Stage 2 cams
    4:10 gears
  7. #7
    May 2009
    Katy, TX
    2 Post(s)
    Get the slave cylinder and clutch line from tommy vaughn. The harness, pcm, crossmember, and pedal assembly either from a junk yard or s197forum. People sell them quite often.
    06 GT. Built by me
    s197forum.com/forum
  8. #8
    Oct 2010
    Liberty
    Thanks for all of the advice and information. I called and talked to the guys at Circle D that built this tranny originally and they assured me that it should give me long term service with little to no problems. It was built with all the heavy duty parts needed to hold up to what this motor is putting out, so they recommended that I have this one repaired. They are thinking the wear on the OD band is probably form previous repeated use at the track, but since I am only going to use it for a weekend street driver, I should get many years of good service out of it. I am going to have it repaired, but if it fails again, I will convert it. But thanks again for all of the helpful information.
    [/SIGPIC]2006 GT
    Aluminator Motor
    Ford Racing heads
    Stage 2 cams
    4:10 gears
  9. #9
    Plantersville
    13 (100%)
    17 Post(s)
    Wait for Beaumann to get their 6r80 controller done and swap in a 6r80 auto from a 2011-2014.
    The 5r55 even built can't handle what a stock 6r80 can
    2014 GT Premium A6
  10. #10
    Oct 2010
    Liberty
    That sounds like a good idea too, if it fails again, I will definitely keep that in mind, thanks.
    [/SIGPIC]2006 GT
    Aluminator Motor
    Ford Racing heads
    Stage 2 cams
    4:10 gears
