Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: A/C Out in 08 Shelby - Anybody use the A/C Pro Kit to Recharge?
    Saleenville
    2 (100%)
    5 Post(s)
    My low pressure service connection is too big for the female end of the recharge kit
    Anybody gotten this to work?
    Is there an adapter required/available?
    Saleen Club of America - Texas State Rep (yeah, I know, but I love Shelbys too!)
    www.saleenclubofamerica.com
    Jun 2010
    2 (100%)
    Thought those connections were standard?? Are you certain you have found the low side port??
  3. Likes ScoottieDoo liked this post
  4. #3
    Saleenville
    2 (100%)
    5 Post(s)
    Thought they were too. I was told the low side was on the passenger side, but maybe that's not correct.
    BTW, that cowl hood looks awesome on your car.
  5. #4
    Jul 2011
    Houston
    1 Thread(s)
    Are you sure it needs a charge?
  6. #5
    Saleenville
    2 (100%)
    5 Post(s)
    Quote Originally Posted by drizzo81 View Post
    Don't know. The kit comes with a gauge that I hope will tell me something.
  7. #6
    NW Houston - Cyfair
    4 Post(s)
    Those charge kits are usually not that accurate I've found. If you really want to tell the pressures, rent real gauges from Autozone. I assume the compressor is kicking in, just the air is not that cool? Found this info on the low pressure location, assuming the GT is the same as yours. http://mustangforums.com/forum/2005-...ustang-gt.html
    Mike Bradburn (redrocker) is the guy that taught me a lot about the AC system when I replaced everything on my Fox. AC work is not that hard if you have the tools like Mike does.
    87 LX 5.0 - bought new 3/31/87 - 306,000+ mile former daily driver with a blown engine. :(
    Ask me about Fox 5 lug info.
    2016 Ruby Red/ Ebony PP GT - new daily driver :D
  8. #7
    Saleenville
    2 (100%)
    5 Post(s)
    Thanks Thomas.
    When it first started to have a problem the compressor would cycle fast.
    I decided not to even try to run it after that till I had a plan.
    I located the right connection, started the car, and now the compressor wasn't cycling at all.
    Thinking I might have blown a fuse, I checked the several fuses and relays involved with it's operation....all good.
    Put the quick-fill thing on and the pressure wasn't inordinately low. BUT, the compressor wasn't running either.
    I went ahead and charged it up a bit, and low and behold, she started cycling.
    Must have been the low pressure switch in the system that kept it from running.
    Put the rest of a small can in with dye, and waaaah-lah! Cold air!
    Think I found the source of the leak at one of those O-ring connections near the fill point.
    When it leaks out again, I'll tackle that.
  9. #8
    Mar 2010
    Spring
    Make sure it's not the Schrader valves in the ports. Those seem to leak a lot on older fords
  10. #9
    Katy, Tx
    8 (100%)
    8 Post(s)
    2008 is "older" Ford?
    Sent from my LG-LS980 using Tapatalk
    Matt
    Texas DPS Engine Swap Info
    Rockin the 2007 S197 GT
  11. #10
    Mar 2010
    Spring
    Quote Originally Posted by 85coupe50 View Post
    Sorry I work at a dealership so to me it's older than the 13 and 14s that I work on.
