Page 146 of 155 FirstFirst ... 4696136144145146147148 ... LastLast
Results 1,451 to 1,460 of 1548
Thread: Hoopty 2.0
  1. #1451
    Jan 2007
    Pecan Grove
    9 (100%)
    11 Post(s)
    Quote Originally Posted by hoopty5.0 View Post
    Quick note -
    My ignition issues don't appear to be fixed. I decided to do a little data logging in the HOV lan--- I mean Mexico yesterday to since I thought my issues were pretty close to fixed. Well, they arent. Downshifted into 4th and let it go. 2500-4000 was pretty lame; lots of noise, not a lot of movement. 4-5000 progressively pulled me back into my seat until I lifted. I thought, "cool, that felt ok."
    The issue became apparent when I looked at the datalog -- 22.4psi at 5000 rpm. WHOOOOPS!
    (side note: I actually did 2 runs, and both said the same)
    Here's the problem - at that psi, the car should have:
    a) blown through the clutch
    b) had an epic 70+ mph rolling burnout with a brown stripe between the two black ones.
    c) all of the above.
    I still think the ignition is retarding for some reason. I'm going to unplug the start +12v from the TFI module again and see what happens. Assuming it fixes the timing issue, I need to log the boost again, but I did set up the overboost control in megasquirt to cut out at 18psi. Probably higher than I'll ever need, but hey, what fun is stopping at a low level?
    I'll report back with more results soon.
    Hmm.. Maybe it may be a good idea to invest in a boost gauge at some point as well?
    "This site is unique from alot of the others. We're a car club that grew a website, whereas alot of the others are websites about cars."- Ultamax
    "I'd put a Westside sticker on my car but I would get Westside in trouble!!!"- Timbostang
  2. #1452
    May 2011
    Richmond
    10 Post(s)
    Quote Originally Posted by Whitey92LX View Post
    Well, possibly, but it's hard to keep an eye on gauges when you're trying to keep the car on the road. I set up the overboost control last night. Once it hits 18psi, it cuts the spark. Sort of like a rev limiter, but for psi.
  3. Likes Whitey92LX liked this post
  4. #1453
    May 2011
    Richmond
    10 Post(s)
    I'm tired of dicking with this TFI mess. I'm selling all the 9.5 ignition stuff and going DIS. Apparently the TFI systems are a major issue for the guys at DIYtuning. Obviously, not everyone has these issues, but I'm at my wit's end.
  5. #1454
    Rosepine, la.
    1 Post(s)
    If you lock out your timing in tuner studio, say to 25, does it read 25 on your balancer with a timing light?
  6. #1455
    May 2011
    Richmond
    10 Post(s)
    Quote Originally Posted by gstewart View Post
    Locked it to 20 and it retards. Although, after doing a lot of reading today, I learned that lots of people have had this issue and nobody on a dozen forums has a solution other than the timing light causes a few degrees of retarding. It's called slew rate, or a function of V/s. Basically a distortion of the square wave.
    Sent from my iPhone using Tapatalk
  7. #1456
    May 2011
    Richmond
    10 Post(s)
    I should clarify.... it idles at 20 and retards with rpm
  8. #1457
    Rosepine, la.
    1 Post(s)
    Have you tried taking it for a drive with the locked 20 degrees with less boost?
  9. #1458
    Rosepine, la.
    1 Post(s)
    Not trying to get you to blow up your motor as long as the boost doesn't spike.
  10. #1459
    May 2011
    Richmond
    10 Post(s)
    I drove it today. Took a datalog, ran it through VE analyze, took another log, etc.
    Still feels like it's bogging really bad from 3-3500 rpm.
  11. #1460
    Rosepine, la.
    1 Post(s)
    Text me a pic of the datalog when it's bogging. When you get a chance.
