Page 156 of 156 FirstFirst ... 56106146154155156
Results 1,551 to 1,560 of 1560
Thread: Hoopty 2.0
  1. #1551
    Lookin good!
  2. #1552
    Mar 2013
    Piney Woods
    Bold color choice. I like it.
  3. Likes hoopty5.0 liked this post
  4. #1553
    May 2011
    Richmond
    10 Post(s)
    Thank you! It didn't turn out right (was supposed to be way more blue) but I'm still really happy with it. I've got a lot more done, just waiting on plug wires now before I try and fire it off.
  5. Likes TxFireman1972 liked this post
  6. #1554
    May 2011
    Richmond
    10 Post(s)
    Not much to update here, I'm not getting any spark at the coils, also found that I modded the MS for a VR sensor when I have a hall effect sensor. Fixed that last night. Need time to do more troubleshooting. Hard to figure shit out in 30 minute intervals each night.
  7. #1555
    Probably just something super simple you are overlooking with everything going on. Once you find it, it will probably be a "smack my head" moment lol
  8. #1556
    May 2011
    Richmond
    10 Post(s)
    I ended up pulling my coil harness I made completely out of the car last night to go through it and make sure I didn't screw something up. Surprisingly, I didn't wire anything there wrong. So I plugged it back in and went through each of the 8 plugs with a volt meter... All 8 of the signal ground wires back to the computer had a rock solid 5 volts.... Uhhh wut?!
    Turns out my 1990 mustang has a 1991+ engine harness in it.
    I soldered the SG to the correct grey/red wire, but then ran out of time. I have a few more checks and test to run, but I can't think of anything else that could be wrong, short of having a set of fried coils.....
    Famous last words, right?
  9. #1557
    May 2011
    Richmond
    10 Post(s)
    Got the grounding sorted and finished my plug wires last night. (OOOooooo, AAAAAhhhhhh)
    Car didn't start though. I took a few data logs and sent them off to a buddy to see if he can help me figure it out. I KNOW I have spark and fuel, so either the crank trigger isn't working right, or the timing offset is way off.
  10. #1558
    May 2011
    Richmond
    10 Post(s)
    https://www.youtube.com/watch?v=qtIJ...ature=youtu.be
    Apologies for shooting this in potato mode.
  11. #1559
    May 2011
    Richmond
    10 Post(s)
    After yet another round of testing, I have some kinks (self imposed, of course) to work out with the crank trigger. There was some ambiguity in the wiring directions and I zigged when I should have zagged. Right now, the signal is all over the place and the coils are firing accordingly. Should be a couple of quick snips and solders and ***hopefully*** the fukin thing will start finally. Unless I managed to FUBAR something else up in the process...
  12. #1560
    I feel my fingers crossed for you!
