Page 141 of 156 FirstFirst ... 4191131139140141142143151 ... LastLast
Results 1,401 to 1,410 of 1560
Thread: Hoopty 2.0
  1. #1401
    10 Post(s)
    Quote Originally Posted by MBR View Post
    I could be totally wrong but I thought I read somewhere that the 93 cars got a voltage signal from the MAF that regulated something with the fuel pump?
    Couldn't say for sure, but mine's a 90, so even if true, probably not affecting mine.
    What I may do regardless is hook the current 12v supply to the pump up to the trigger pin on a relay and run a fused lead from the battery to the relay and then from the relay to the pump - and use a large gauge wire. This will eliminate any chance of voltage drop.
  2. #1402
    10 Post(s)
    Well, I used my redneck ingenuity and stuck my GoPro to the fender with a flash light shining at the fuel pressure gauge and went for a drive. I did regular driving and beat on it a little to make it break up some.
    Fuel pressure was rock solid and went up with boost.
    F***.
  3. #1403
    Katy, Tx
    8 (100%)
    8 Post(s)
    So where's the video? Did you lose the GoPro?
  4. #1404
    10 Post(s)
    Quote Originally Posted by 85coupe50 View Post
    Hahaha it's not worth watching. Just a fuzzy shot of a fuel pressure gauge. Too loud to even listen to the volume
  5. #1405
    10 Post(s)
    I may have a spark box headed my way. I was told to add one a long time ago by this friend and he reiterated it again tonight. He had the same problem apparently
  6. #1406
    10 Post(s)
    ...and by Rick too. You'd think I'd have learned to listen to people by now.
  7. Likes SSPSTANGBANGER liked this post
  8. #1407
    Cypress, TX
    Quote Originally Posted by hoopty5.0 View Post
    like a MSD box?
    1993 Coupe
  9. #1408
    10 Post(s)
    like a MSD box?
    Yep.
  10. #1409
    Cypress, TX
    Yep.
    so you think its spark blow out due to a weak ignition?
    1993 Coupe
  11. #1410
    10 Post(s)
    I don't know for sure, but it's the best course of action I can see right now. I've had @SSPSTANGBANGER tell me I needed one and another buddy told me a long time ago I needed one. My thread on the turbo forums seems to have the same opinion if fresh plugs and a tighter gap don't get me there.
    I was able to rule out fuel system errors and yesterday, so that's a plus.
  12. Likes SSPSTANGBANGER liked this post
