Page 153 of 153 FirstFirst ... 53103143151152153
Results 1,521 to 1,530 of 1530
Thread: Hoopty 2.0
  1. #1521
    Houston, Tx
    That block is almost as pretty as the turdbo, almost.
    -- Admiral Aaron
  2. #1522
    May 2011
    Richmond
    10 Post(s)
    Quote Originally Posted by Snipe656 View Post
    The turbo is gonna be soo prettaaaay once it's coated, too!
  3. #1523
    May 2011
    Richmond
    10 Post(s)
    Today, for the first time in about a year, i entered my garage with the intent of working on my car.
    ...unfortunately, i didnít get very far. I got the block painted (black) and cleaned the oil pump and pickup out. I need a new shaft, mine got bent somehow. Looks like it hit the crank too? Strange.
    Also going to lightly sand the bottom plate of the pump. Nothing there thatíll catch a fingernail, but Iíd feel better if it got sanded.
    Sent from my iPhone using Tapatalk
  4. #1524
    Houston, Tx
    I might have a new shaft still in the packaging from Ford Motorsports sitting in my garage. I think it is for a 351 but maybe 302, if I can find it I will pass the part number over to you to see if it work for you and if so you can have it. If you have interest in it, not like they cost much new anyway. All I know is I have zero plans that ever would actually use the part.
    -- Admiral Aaron
  5. #1525
    May 2011
    Richmond
    10 Post(s)
    1/4Ē vs 5/16Ē
  6. #1526
    Houston, Tx
    M-6605-A302 .... can't remember why I have this thing, has a note on it that states will not fit 1986 to present 5.0L EFI engines due to a change in distributor housing lengths. The thing is so old that the brand on the packaging is "Ford Motorsport SVO Performance Equipment". Maybe I can sell it as an antique one day.
    -- Admiral Aaron
  7. Likes hoopty5.0 liked this post
  8. #1527
    May 2011
    Richmond
    10 Post(s)
    Ah, yeah, wonít work. Need P/N M-6605-A341 from what the interwebz is telling me
  9. #1528
    May 2011
    Richmond
    10 Post(s)
    Bought a new oil pump and an ARP shaft, then got the bottom end finished out last night. Almost got the heads bolted on but it got late on me. Will try again tonight.
  10. #1529
    May 2011
    Richmond
    10 Post(s)
    Went to install the cam last night and noticed the intake lobe on #1 had a nasty gouge in it. After talking it over with a few folks, including the machine shop, Iím going to run it... i donít really have any other options right now. Also, new lifters are on the way, no telling a whatís inside the old ones after the bearing let loose.
  11. Dislikes Neighbors disliked this post
  12. #1530
    May 2011
    Richmond
    10 Post(s)
    Got a new-used cam, installed it with my newly coated timing cover from Scott - amazing work as usual. Also threw on the trigger wheel Iíve had for a while. Not sure when Iíll get around to using it, but hey, itís on at least.
    Got a couple more parts to install before it goes back in the car for good!
