Page 45 of 45 FirstFirst ... 35434445
Results 441 to 442 of 442
Thread: 1993 Electric Red Coupe
  1. #441
    Quote Originally Posted by hoopty5.0 View Post
    Damn man, that's just as bad as those P heads I got a few weeks ago!
    They cleaned up ok, it's just the principle. So if he lied about that, who knows what else he lied about. I have a few boxes coming tomorrow from Texas Speed
  2. #442
    Well I tried unsuccessfully to work something out with the seller of the LS2, but in the end he basically told me to F@*k Off. Was hoping for a little $$ to help out with the extra parts it needs, but no luck, even after many promises that he would. So I'm cutting my losses, using it as a learning experience and moving on. I ended up pulling the heads completely apart, cleaned them all up and after several hours I had them back to usable condition. I had someone wanting them, so I sold them.
    I picked up a nice set of used Texas Speed heads.
    PRC Stage 2.5
    Fully CNC Ported
    LS6 243 castings
    Upgraded 2.02/1.575 stainless valves
    Milled .020
    The FedEx man has made several stops at my house lately!
    PRC heads
    Texas Speed Torquer v.4 Camshaft
    TSP PAC POLISHED .660 dual valve springs
    Titanium locks and retainers
    CHE bronze bushing trunion upgrade kit
    Comp Cams pushrod length checker
    Rocker arm bolts
    Main cap bolts
    ARP headstuds
    GM high performance oil pump
    Oil Pump O-Ring
    LS7 lifters
    Lifter trays and bolts
    TSP valve seats/seals
    LS2 head gaskets
    LS2 timing chain
    Clevite main bearing set
    Sac City oil barbell upgrade
    Sac City oil pickup hold down
    Torque angle gauge (for main bolts)
    Here are links for the Sac City oil barbell upgrade and the oil pickup hold down:
    http://www.saccitycorvette.com/Billet-BarBell.html
    http://www.saccitycorvette.com/OilTubeHoldDown.html
    The heads were milled .020 so that should have put them around 62cc. I wanted to measure them just to make sure I knew what I had. Came out to just under 62cc, give or take a little on each one.
