Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: 95 cobra roller for sale
    Aug 2010
    For Sale:
    1995 Mustang Cobra roller
    $4500 OBO
    Exterior:
    H.O. Fibertrends Cobra R 2.5 cowl hood
    All other stock body parts intact
    Wheels:
    Front Bogart R/T Welded 15 x 3.5.
    Rear Bogart R/T Welded 15 x 10 w/ 6.5 backspacing.
    Tires:
    Front Mickey Thompson ET Tire 26 x 4
    Rear Mickey Thompson ET Drag stiff wall 28 x 10 (approximately 20 passes)
    Brakes:
    Strange lightweight brakes front and rear
    Hurst line-lock system with push button
    All new front brake lines with ABS system removed
    SKRC manual adapter setup
    Suspension:
    Front:
    Ground Pounder tubular k-member
    Ground Pounder tubular a-arms
    Ground Pounder coilover sleeves
    QA1 14 x 120lb coil springs
    Maximum Motorsports caster/camber plates
    Strange 10-way single adjustable struts
    Rear:
    AFCO double adjustable shocks bolt in stock location
    Rhodes Custom Auto double adjustable upper arms w/ 5/8 bolts
    Baseline Suspensions single adjustable lower arms w/ 5/8 bolts
    Baseline Suspensions anti-roll bar
    AFCO stock style 225lb springs (installed)
    AFCO stock style 225lb springs (1 coil cut in the box)
    Stock 88 rearend housing
    Moser 33 spline axles
    Moser spool
    Ford Motorsport 4.56 gear set
    Moser differential cover
    Electronics:
    Switch panel under radio
    Two battery boxes in the trunk with legal bracing and boxes
    NHRA legal cut-off switch
    MSD 6al ignition box
    Relays located in one location for simplicity
    (No engine harness for EFI)
    Fuel System:
    Glenns Performance Tank
    Pick up tube with -10/-6 fittings
    Two Walbro 392 GSL inline fuel pumps
    Aeromotive inline paper type filter
    Aeromotive 2 port fuel regulator
    -8an supply line
    -8an return line
    Extras:
    Good radiator
    Good radiator SN95 electric fan
    Transmission oil cooler mounted to the radiator
    B&M shifter setup for reverse shift C4 transmission
    Rear seat delete kit
    Kirkey aluminum seats both driver and passenger seats
    ACC carpet kit
    6 point roll bar
    MARIO 832-374-7474 TEXT FOR PICS
  2. Likes Whitey92LX liked this post
  3. #2
    Plantersville
    13 (100%)
    17 Post(s)
    Very nice car
    Glws bro
    You need this 2011 Coyote that's in my driveway
    2014 GT Premium A6
    Sleeved Block 80MM Billet 3BB Comp turbo Full Suspension tuned by Black Mamba Speed - 138.8mph pedaling on 10psi
  4. #3
    Aug 2010
    Still for sale..complete engine and tranny too. Maybe custom trailer that fits in garage too.
  5. #4
    Jan 2010
    Houston, Tx.
    3 (100%)
    Can you text me? 832-790-0950. I texted the number in the ad and they said I had the wrong number
    '99 MUSTANG SALEEN/COBRA #320
    '99 MUSTANG SALEEN #201
    '86 CORVETTE
  6. #5
    Aug 2010
    Fixed the phone number.
  7. #6
    Aug 2010
    Ttt
  8. #7
    Aug 2010
    Ttt
  9. #8
    Nov 2004
    Is the car still for sale
  10. #9
    Apr 2015
    parrish
    1 Post(s)
    Still for sale?
  11. #10
    Baytown,TX
    Trophies
    What motor and tranny u got?
    Whipple 3.4 ( Gone )
