Hey all,
I have an innovators West 10% OD crank pulley on my Teksid block 3v and it does not contain any of the timing indicators the stock crank pulley has. Every go-by and instruction I have seen for replacing the cam phasers with the front cover on references the marks on the stock pulley. Can the crank location be determined from the cam position or any other way with the OD still in place?
I don't believe I still have the stock crank pulley (to transfer marks, or set to install temporarily to do the job), and I was looking for a way to do the job without removing the crank pulley or front timing cover and all the accessories.
Any ideas?
