Results 1 to 9 of 9
Thread: crazy idle problem nned help
    Sep 2012
    Spring TX
    ok so here it is . i have an 02 ranger with the 3.0L w 5speed. it randomly started the other day when i turned the cruise control off . so when the car is in motion and i push the clutch in the RPMs will run up to 3k then when i stop it will surge between 1k-2k then run up to 3k hold for a few seconds then drop to 2k for a few second then down to 1k then back to 2k then 3 k then down its got me so lost ive put on a new IAC and TPS very frustrating . PLEASE HELP!!!
    1989 Saleen #173
    Coyote swapped
    forged balanced internals , comp cam Stage 3 cams , BBk longtubes , O/R Xpipe. built T56 , 3:55 rear gear
  2. #2
    Put the 306 in it
  3. #3
    Sep 2012
    Spring TX
    haha no! thats goin in the leen .
    1989 Saleen #173
    Coyote swapped
  4. #4
    May 2012
    Katy, TX
    Any codes?
  5. #5
    Sep 2012
    Spring TX
    IAC and TPS both replaced, no change .
    1989 Saleen #173
    Coyote swapped
  6. #6
    Mar 2010
    Spring
    Parker ill ask the drivability guys at the shop. Maybe I can sneak the IDS out of the shop and check out this weekend.
  7. #7
    Sep 2012
    Spring TX
    that would be great. only problem is im away at work and wont be home till the 21st .
    1989 Saleen #173
    Coyote swapped
  8. #8
    Mar 2010
    Spring
    Aight well ill see what I can find out and when you get back ill see if I can grab it.
  9. #9
    Sep 2012
    Spring TX
    That would be a big help . I feel like I'm chasing my tail.. its almost like the computer it telling it to do all this.
    1989 Saleen #173
    Coyote swapped
