Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Distributor won't seat
    Sep 2009
    Deer Park
    I have a melling oil pump, ARP oil pump shaft, and stock distributor and I can not get the distributor to seat all the way.
    What are my options? I am leaning towards cutting the distributor down, but this gap seems excessive. (LOL)
    2001GT-Auto YSI (2.7/15%OD)<br />89 LX 5.0 (347 stockish)
  2. #2
    Sep 2009
    Deer Park
    I am guessing that the issue is the little stop installed on the distributor from ARP. I hope that is that the problem is because if the ARP is actually bottoming out on the distributor cutting the distributor won't help.
    Any help is much appreciated.
  3. #3
    Sep 2009
    Deer Park
    Can I take off the distributor shaft, stick it in, and then get out a hammer to see if I can tap that clip/retainer down some?
  4. #4
    Dec 2007
    SE Houston
    Been there before, I just dropped the pan and took it out... I know it sux ass but had to do it
  5. #5
    Sep 2009
    Deer Park
    you took it out and did what with it?
  6. #6
    Aug 2006
    Tulsa, OK
    Is it the same block the dizzy came out of?
    Darren
    '83 5.8L TKO'd T-Bird on the bottle
    '93 5.4L Mustang coupe that beat your mom's LTD
  7. #7
    Sep 2009
    Deer Park
    Different short block with factory block, melling oil pump, ARP oil pump shaft, old stock (car quest) distributor.
  8. #8
    Dec 2007
    SE Houston
    Took it out and measured the stop ring to the factory one, then presto!
  9. #9
    Sep 2009
    Deer Park
    Well, I do remember that I looked at the two shafts side by side and the length was pretty much the same, but the stop ring on the ARP was closer to the distributor some. I just figured that this had something to do with the ARP shaft and would not hurt the distriibutor engagement. Looks like I was wrong.
    I will cut a little on the distributor shaft and see if it seats further. If so I will continue to cut until it seats easily. It seems that this has been a common solution for the idiots in my situation. LOL
    Any reason I shouldn't do this?
  10. #10
    Dec 2007
    SE Houston
    I heard if you do that, just take it apart first cuz the vibrations from cutting can damage parts...
