Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Welding help
    May 2012
    Houston
    Welding help
    New to welding, so i bought a northern tool 125 to start out. Welding with flux core, i can say i can weld thick stuff pretty good. Now i am trying to weld 16 gauge sheet metal but i keep blowing through. It only has two volt settings and its at the lowest. Is it possible to weld that thickness with this welder, any tips. Thanks
    Sent from my iPhone using Tapatalk
    Aug 2006
    Houston
    2 (100%)
    most likely will not be able to weld that.. it gets to hot for that thinner metal.. maybe move a little faster or do short beads
    1994 Mustang GT
    331 C.I.D Roush heads,Comp XE282HR 1.72 stud girdle, ProPowerParts stroker kit 1200hp rating, Ross pistons
    HURRICANE EFI, BBK 75mm fox TB, 60lbs injectors, TKO600-.82 , On3Performance.com turbo kit........
    1962 Ford Falcon Back-half, full cage spec for 8.80, 331 C.I.D ,custom grind crane mechanical roller camshaft 672 lift.
    May 2012
    Houston
    Its blowing through on contact.
  4. #4
    Feb 2011
    Crosby
    You need a machine with lower settings and use mig wire with that thin of metal.
    03 Dodge ram QC {Hemi}
    88 Lx {supercharged}
  5. #5
    May 2012
    Houston
    Welding help
    The thing claims it can do it , i am running .035 wire. Do you think .030 wire could do trick?
  6. #6
    Feb 2011
    Crosby
    No it's still gonna be too hot.
  7. #7
    May 2010
    6 (100%)
    Add c25 and mig steel wire 35. Usually those machines will convert to mig. You will not be able to weld that gauge with flux core.
  8. #8
    Pearland
    At 16ga (.0598" thick), use the smallest wire you can get, .023" and gas...
  9. #9
    May 2012
    Houston
    I ended up getting .030 flux and i have to stitch weld. For what i need it, i think i will be ok.
  10. #10
    Katy
    I ran into this issue with my cheapo harbor freight welder trying to fill holes in the inner fender a while back and ended up giving up. But it made a good plasma cutter.
